Turbo Is200
hi i have just got a is200 on 1999 and i wont to sart to modifi it wont to put a turbo on it dos enay one naw what turbo is best for it ? and if enay one no of enay good mods to do to it thanks
My understanding is that getting a used TTE supercharger kit would be the cheapest way to go, around £2000. To turbo, the engines aren't strong enough as standard, so as well as the turbo, the internals would have to be upgraded. Mega bucks.
1JZ-GTE or 2JZ-GTE engine swap but as said above it involves a lot more cash . some guys in US are runing V8 LS engine swaps into the IS chasis..but i went the easy way and got an IS300. it has enough speed in stock form and if you want to go turbo, check out the engine block the IS300's carry under them :winky:
