Hello all.
After 135k miles it looks like my radiator has given up. Having had a look at it, it doesn't look the most difficult job in the world.
I've been having a look and I know I need the type with the extra ports as it's an Auto gearbox model. However, there seems to be 16 and 25mm core models available. Do they differ in physical dimensions, or is one just a cheaper version than another?
Also, if anyone has any experience of changing these, particularly on an auto, any advice would be much appreciated.
Thanks in advance!
hi i think the aftermarket rad core is 16mm and original is 25mm not to hard to change
I can get 16 and 25 aftermarket. Just wondering if anyone had any experience of changing one to pass on before I attacked it.
From reading past posts they are interchangeable.
My main consideration is the extra pipes on the auto model. Was wondering if they were oil pipes used as oil cooling (so a seperate section of the rad) or they're just extra water circuit to feed a water to oil heat exchanger as part of the gearbox.
So am I going to find ATF or coolant when I pull these two pipes?
i changed the rad in my manual not hard to do at all ,the rad i put back in was a auto i just didnt use the bottom tank if you have a auto make sure you but a rad for an auto !
Drain rad - should be a drain plug at the bottom of the rad
undo all pipes and top 2 brackets
Lift old rad out
put new rad in
do up all pipes
fill with water and turn on engine with heaters on full
when water goes down top up till full do this for about 10 mins so there are no airlocks.
Job done have a beer.
* Not sure what is in the bottom pipes water or proper coolant for the A/T box.
Thanks for that mate. Will attack it soon as it's getting worse.
I've come to the conclusion that the extra pipes are oil pipes as it combines as a radiator and oil cooler. So best remember to get a bit of ATF oil too to top that back up afterwards.
Did mine on my IS200SE Auto 2 weeks ago.
Very easy to do.
Original thickness was 25mm, 16mm can be fitted which is the one I have used.
£80 from ebay delivered by courier the next day.
No problems whatsoever.
Cheers mate. Have gone with the cheap one. Will report back when I get round to doing it.
Thin one was a manufacters upgrade to save manufacturing costs, same fitment and everything, does the same job, no less or more, unless you count it towards weight reduction, easy job, you can't go wrong. Just make sure you don't break any fan plugs or cable clips as at 135k, they will be brittle.
Cheers for the advice folks.
Turns out it was a nice simple job to do and not much messing around.
I'd advise anyone doing it to fill the engine block first via the top hose before connecting it to the radiator and completely filling the system. With the car on ramps this meant I didn't get any air locks. Oh and the oil loss from the Auto gear box is very minimal, so only requires a squirt of replacement oil. Will be changing my oil soon anyway.
thats a shame i didnt see this in time ive got a brand new 25mm core rad for a is200 with the auto connections that i bought and ended up with 2 for some reason , its just sat in my garage now.its a nippon type and its a perfect fit like for like with the lexus on i took off
  • Similar Content
    • By Blucky
      I have a 1999 Toyota Altezza 1GFE, which recently has had the engine light come on after driving it for a few minutes. Every time i restart the car it goes away but comes on again after a few minutes.
      I have done the paperclip diagnosis on the ODB1 port, but all it does is make the engine light, ABS light and the ECT light flash continuously.
      Does anyone know what it might be?
      Cheers,
    • By mondo35
      Hi guys, i have owened 3 lexus is 200s
      and I absolutely love them,
      just recently i thought about having a caravan so i sold the sport and got the is 200 SE
      I have the tow bar and everything, i want to know how much the standard is 200 weighs.
      as my car and caravan must be 3.5 tonne or under. Now can anybody please tell me how to find this out, i have looked online allready but have had no luck
      thanks in advance for all the replys,
      much appreciated
    • By SHOEY94
      Hi guys,
      first time posting here on this forum looking for help. I currently have a 2000 Lexus is200 as my weekend (fun car) while my daily was in getting repaired I was driving the Lexus as a daily but when my main car came back I parked the Lexus up starting it every so often. Then when I went to start it one day it just kept turning and fuelling but would not spark. I had to charge the battery also. I checked power to cool packs and they all have power going to them. I've checked all fuses and nothing seems at fault there. While I was driving it as a daily the plastic part of my key, which is the only one I have for it, split. I glued it back together but I've a funny feeling this is the issue that the chip isn't sending out a signal. When I put the key in the ignition the red dot security light is not lighting up! Does anyone have any ideas or people who could sort this for me ? I'm in the Meath area of ireland.
      Much apprecited.
    • By JoshMaffers
      Hello guys, hopefully I have posted this in the right location.
      I have a Lexus is220d, when driving after about 30 minuets or so, or after high engine revs the temperature gage rises and shows that the car hot. After about 30 seconds it then drops down to the normal temperature again. However after 1-2 hours of driving the temperature then rises and very rarely drops, when it does drop it is only very slightly. When I checked, the engine water had sprayed all over the top of the engine from the water reservoir and there was no water left in the reservoir. Also checking the water that had sprayed on the engine, it is not oily. I am having to top the water up every day, sometimes twice a day. When the temperature is normal the heating in the car works, but when the temperature rises the heating goes cold, even on max temperature. The engine runs perfectly and when opening the oil cap it is not grimy and it is clean. Finally when opening the reservoir cap to fill it, the pressure is being releases causing the reservoir to fill with the water again and spray out of the overflow pipe.
      I have seen some people mention that it could be the head gasket, however a mechanic mentioned it sounds more like the thermostat, any ideas?
      I have ordered a thermostat and I will replace that, however I can't find anywhere the actual location of the thermost. All of the guides are for the 250, which is different and it is not in the usual simple location, at the top of the engine. If anyone could point me in the right direction of that, it would be extremely helpful as well!
    • By Yobosoku
      Hi, new to forum, there may be an already existing thread but I cannot find anything......ANYWHERE! I need an ecu pinout for a 2001 is200 using a 1gfe with an ecu number 89661-53200. I need this pinout diagram and expertese to fit a bee*r limiter basically because I want one and I like being a loon in my car. There are people who hate/disagree with them, however I would like one in my car and I would appreciate help fitting it.
      any help appreciated.
