AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
omeo
Is200 Power Steering Fluid
omeo    1
Hi Guys this may be a stupid question, but I need to top up my power steering fluid for my is200 manual gear box.
I went to halfords and they checked on the system and said it that PSF was recommended for my car but the manual i think is saying to use ATF 2/3.
Which is the correct fluid I need to top up my power steering, thanks???
omeo    1
thanks for your answer, i will get it refunded. Is it ok to top up the power steering fluid already present or should i drain the power steering fluid out and replace it all??
clifton 94    19
no you can just top it up but if it needs topping up you will have a leak so best just to top it up and check for a leak also most power steering fluids and auto gearbox fluids are the same just look at the spec on the bottle normally red in colour
lexus loon    16
Omeo,its easy to drain the fluid by undoing the bolt on the pump,and then top up as normal .
carlo68    0
Hi Guys,
Ive got a leek from the pipe at the front of the radiator, it looks like its actually leaking from one of the rubbery pipes.
I was thinking of using slick 50 power steering repair fluid, anybody got any comments on that ?
cc
ColinBarber    489
Hi Guys,
cc
I would fix it properly
WGC_Bloke    0
This is a first for me, but I'm going to have to change my steering fluid. I see the IS200 isDetron 2 or 3, but does anyone know how much I'll need for a complete change? thanks folks
iffy    0
is there any diys for this task
