• 1000's of Lexus For Sale
    • Massive Choice on Lexus Parts
    • Join Gold & Save!
      Join Gold & Save!
    • Save Up To 15% On Your Lexus Insurance!
    • Get Your Club Gear
      Get Your Club Gear
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
webby73
Remote Wont Lock/unlock
21 posts in this topic
Hi i have a is200 and until yesterday my 3 button key remote was working fine i unlocked my car drove it got out tried to lock it and nothing happened i changed the battery the little red light blinks when i press all 3 buttons but it still wont lock/unlock car . As i already unlocked the car could i lock/unlock it without the alarm going off .Do any of you have any idea to what could be wrong please.
Sounds like your key has become un coded from the car. Does the key start the car? Don't know how this happens but it's happened to me as well. Do you have a spare key? Not good just to have 1 key. If you loose all keys to this car it's an absolute nightmare!!
You can re code the key to the car by following the pedal dance routine on this thread
http://www.lexusownersclub.co.uk/forum/topic/81219-one-key-not-starting-the-car/?fromsearch=1
As for locking your car without the alarm going off while your key doesn't work.... Get out of the car and using the button on the drivers electric window panel lock all the doors. This will lock all the doors except the drivers door. Now simply lock the drivers door with the key. The car will be locked but the alarm will not be armed. The immobiliser will still be on tho...
The pedal dance is to get the key to start the car... Sounds like you need to do the door dance as well to programme the door locks to the key. This is also on that same thread I linked, just further down :)
hi thanks for replying i am using the spare key now as my other key fell apart when i started the car one day . The key im using at the moment does start the car its just the remote that isnt working .
Is the key you are using a masterkey? I.E. is it black with 3 buttons?
Wait for few hours , try it again, I'm sure it's well work.
Mine didn't Panya... Once it stopped unlocking the car it wouldn't work again until I coded it.
That's was happen to me before, than Lexus ask me to book a car in for reprogram, but it's work few hours later!
Haha magic key fairies Panya.... :lol:
yes its the master key 3 buttons , And this happened last night so i have waited a few hours i left it unlocked all night it wound me up didn't want to lock it in case i couldn't turn off alarm.
So now you know how to lock the car if the remote doesn't work without arming the alarm as I put in my first reply. So you'll never be in that position again of having to leave your car unlocked all night.
Good news that it's a masterkey. Should have no problem coding it back to the car using the door dance method.
Good Luck :)
could you post the instructions on this post please for the door dance and will it mess anything else up on the car if it dont work. thanks for your help
Ok here you go:-
To programme the door (and boot) opening of the remote:
Start with the driver's door open.
Insert a working Master Key (3 button) in to ignition, turn to on, then off and remove.
Lock, then unlock all the doors using the POWER LOCK button on the drivers door FIVE TIMES (lock unlock lock unlock lock unlock lock unlock lock unlock)
Close drivers door, then re-open.
Lock, then unlock anotheR FIVE TIMES, exactly as before.
Insert your new key into the ignition and turn to on, then off agAin and remove.
The door locks will then start operating.
While they are clicking away,hold down the lock button on the new key and press the unlock button on the key 5 times. Then release and press unlock button once.
The doors will lock and unlock once...and ure done!
No it won't mess anything up. I failed a few times at doing this. It can get frustrating!
so i take it i can use the key i was using before the only key i have that stopped working .
Yes this method should code your key back to the car.
Thank you Chris for you help i will give this a try in a while and will let you know if successful or not.
disconnect battery may be ? ? :whistling:
Worth a try^
Didn't work for me but you never know! Disconnect the negative terminal for half an hour... :)
Just tried the instructions you posted and it worked first time the key works cant believe it. thank you .
Happy days.... Result! :)
1 person likes this
On 08/06/2013 at 0:45 PM, ChrisIS200SportTTE said:
Ok here you go:-
My master key has stopped opening my doors and boot and won't set my immobiliser either but it turns the engine on. Turns out my spare is the same. Is this method supposed to work? I can't get it to work.
"The door locks will then start operating" on their own or by me pressing something?
"While they are clicking away" I need to ask if I'm doing this right. She's ups I be locking and unlocking a third time? Should I be doing two things at the same time? I don't know how I'll lock my car tonight.
Should I be holding down the lock button at the same time as pressing unlock 5 times?
  • Recently Browsing   0 members
    No registered users viewing this page.
