Aoutomatic Transmision - Oil Top Up
VoipX1
There is normally a proceedure for checking the transmission oil which should be in your owner's manual.
There are 2 markings on the dipstick, Hot and Cold levels. The Hot measurement is more accurate but the car needs to have been driven 10-15 miles before checking.
Whichever method you use it is normally start the engine then move the selector slowly from Park to L and then back again to Park.
Then with the engine still running immediately pull the dipstick,wipe reinsert and check the level.
If you don't have the owner's book and would like one send me a PM as I have a spare going cheap.
So after doing that I can see the two levels cold and hot, when doing above as I have done the level just touches the hot mark...
Should it ideally be any higher ? there is a third mark a few inches above the hot one.
