My passenger side rear window has stopped working. The other three windows all work.
Was fine yesterday when I closed it. But this morning it wouldn't go down. Wont work on either the drivers master switch or the door switch. Has anyone got any ideas where to start with diagnosing the problem. Many Thanks.
As above.
If this fails to find the problem and the set up is the same as the LS400 each door has an ECU attached to the inside and this can glitch. In my case unplugging it and reconnecting it sorted the problem.
