Changing Timing Belt Couple Questions?
jrsimon27
Hi freinds i took my lexus is200 with 60,000miles to get the timing belt changed at the dealership the thing is that i bought the original kit from the dealer and now they are telling me that they need to change the o ring or sometime of seal from the camshaft and cranckshaft is this true? Thanks in advance.
its just below the rocker gasket cover on the right,sorry haven't got a picture to show you(sometimes has a slight pink staining round it if you use pink antifreeze that is).hope this helps.
