Servicing/timing Belt
AUFC
Getting the car serviced, its sitting at 83k. Will be going for a full service, what other things should I get done? What oil do I use?
Should I get the timing belt replaced at a certain mileage?
There is a shudder in the steering when braking, expensive fix?
Much appreciated!
Was cambelt done at 60,000miles?if not overdue now,you may also want to change water pump for piece of mind too,have your brakes checked too then,think oil is 05/30,hope this helps.
  • 4 weeks later...
