Weird Audio Problems
Hi Forum readers,
I wonder if anyone has come across this problem before? Recently my radio stopped working even though all the visuals were working but when I pressed the sound icon in audio section it could not be adjusted. A couple of days later my Battery went flat and the AA came out and checked it and I needed a new Battery although the alternator charge tested fine. With the new Battery fitted the radio started working again. However, since then every so often the radio loses sound again and if I disconnect and reconnect the Battery it starts working. Does anyone have an idea what may be causing this and a possible remedy.
hi looking on your profile you have a ls430. When I worked at main dealers ls430 used to suffer from amp probs causing similar faults that you have especially on levinson amps hope this helps
Sent from my GT-I8190N using Tapatalk
Hi Dave,
Thanks for the info. Do you know if they can be repaired or is there an after market replacement amp that can be used instead of the Levinson?
Hi not aware of any aftermarket replacement and when we used to send them for repair nobody could get parts but that might have changed! I have fitted customers secondhand amps before as new were really expensive! Someone on forum might know of any though
