18In Wheels On A Lexus
krayze2k
  • 1 month later...
If you buy a new set no problem but be wary with 2nd hand alloys,check them very carefully for damage/repairs and make sure they are all true i.e. not buckled ( very difficult if not on the car and driven).
Also bear in mind Lexus wheels used sleeved nuts whereas aftermarket tend to use tapered and of course check they will fit regarding PCD (5 x 114.3) Bore (60.1) (spigot rings available) and offset.
Lexus OEM alloys are well known for corrosion problems.
