Toe Control Link Nut And Bolts
hi can any one tell me where i can get new rear toe link nuts and bolts from with out going to main dealer as i was try to get my wheel aliment done but they couldn't get the nut off as it was seized on and told me to get new nuts and bolts for both side so they can cut or break the old ones off.
are the rear camber nut and bolt the same as the toe link ones or are they a different size as i have an old set of rear camber nut and bolt.
are the rear camber nut and bolt the same as the toe link ones or are they a different size.
There's a parts supplier on eBay. I got my rear Lower Control Arm bush from as Lexus said they'd only sell the full assembly and would've cost a couple of pounds . . . . and then some . . . . before I post the name, i'll double check with Ian if it's allowed on the main page of the forum.
Or do what I did.
A good garage/mechanic will be able to unsieze them and re thread them to as good as new. :)
got it off by my self used a long breaker bar to loosen it then of it came.
Hi Shekie. Bit late with my reply, but here are the details, encase you ever need to use them in the future.
AK Autos Limited japeurocarparts akautosltd@hotmail.co.uk
If you search eBay for japeurocarparts this will take you to the seller.
