High Beams For Drls..
Has anyone done this on here like the us spec is300 if so would you be kind enough to point me in the direction of a wiring diagram or show me how youve done yours... obviously I know its got to run less power and most probably through a resistor and has to work at full power for mot which id guess using a relay to switch the drls off once the full beams are in use but this wiring stuff baffles me unless I can see it
Thanks in advance
Dean
