Seat Belt Buzzer
200h
Connect the seat belt............
Drivers belt should not be an issue as you should always wear a seat belt. Passenger side - should only warn when there is a person in seat ( weight sensors ) and should not give out warning with no occupant.
i do always wear my seat belt but when i am driving on the service road leading to my house i normally take my belt off as i need to open my gates and reverse onto the driveway and the buzzer gets so loud on our aygo you can override the buzzer and mute it, just thought you maybe able to do on the ct
Hi is are you sure you a hearing the seat belt buzzer and not the reversing buzzer as on mine the seat belt buzzer will not go off untill you get to about 8mph. The reversing buzzer can be changed to 1 buzz when engaging reverse but only by the dealer.
You can do this and more coding / diagnostic on your own using Android phone, Carista OBDII app (pro version costs abt £12) and OBDII BT adapter (abt £6.00).
i have carista with the upgrade and it does work well
i have found out today in the next release of carista it will have the option to turn off the buzzer for the seat belts so i will be waiting for the next release to become available.
  • 4 weeks later...
today i have used the beta version of carista and the seat belt warnings can now be turned off, the options you have are
drivers ,passengers and rear they are all individual,it could be handy if you put boxes on the seat that set the alarm off
as you may not be able to fit them in the boot
if you sign up for a tester at carista then you get everything for free
including the overheating alert on your phone ,but for this to work
you will need an Bluetooth adapter plugged in.
