colin_agora
Newbie: Current Mpg Display In Multi Info Screen
Hello All I am a Newbie 2014 IS300H
SE Premier Sat Nav, owner. Great, car smooth and quiet and the sat nav works!. (see below)
Previous car was a 2013 Toyota Prius T5 Spirit which was great technology but a crap car!!. Driving the Prius around town and short trips, fab economy but the first long road trip see to my youngest daughter was fraught with problems. The road and tyre noise was unbearable at any speed over 60 65 mpg so much so it made my wife feel ill and all the racket gave me a headache. The A12 is a particularly atrocious bit of road at the best of times apart from the traffic, so hence the Lexus! Ta Dah. Don’t get me get started on the Toyota TouchandGo satnav, the trip from Ipswich to Lewisham using the hand held Garmin was easy enough A12, M25, A20 the Toyota TouchandGo was unbelievable, told me to all way way around Ipswich then onto to the A12 and then turn left off the A12 crossover to Coggelesham over to the M11 down the M11 though the Blackwall tunnel round the South Circular what!. The Lexus on the other hand was direct and to the point A12, M25 A20 no problem. I’m still getting used to the car and the more I find, the more I like. One question for the Lexus officiandos out there, How to I get the “Current MPG” to display on the small multi display between speedo and power meter?. I know I can view this on the central info/Sat Nav screen using the mouse but it would nice to have it on the multi display screen next to the speedo. All i can seem to get is "Average Speed/Time/Distance" Cheers
You select what appears on the Multi Information Display with the Settings option. You need to be stopped to change these.
Press left or right on the joypad on the wheel until you see Settings on the MID.
Then use Up, Down and Set to change the Drive Info 1 & 2 settings to your preferred options.
Drive Info 1 has the option for current MPG I think.
You might have to play around a bit (or look in the book if desperate!) - there's quite a few options and it's not easy to explain in a few words.
Welcome to the club :)
Hi Colin, welcome to LOC. Those of us with a dated Lexus sat nav can appreciate your delight!!
Thanks guys, I've found it but it's not what I thought, it's "average mpg after reset" but I had to do a reset , (press the volume on/off button) to get the additional options. All appears to be working as expected. Long drive tomorrow, we'll see how it goes, cheers.
There's several options, including "average after refuel" which is the one I've got set.
