Can anyone explain why, with the engine of my recently-acquired 430 started up and running smoothly, seat belts fastened, all doors closed and no warning lights on the dash, a loud beep sounds for perhaps half a second. It is designed to sound imperious, is loud enough to startle and me and my passenger, and is unlike any of the chimes and beeps caused by, for example, the parking aids - but there is plainly (at least in my judgement) nothing wrong, and subsequently the car drives perfectly.
Is the key in the ignition or you have it on the keyless start mode.
Could be the fob Battery, mine did a similar thing, but i do think it gives an out of range warning on the dash so may not be your issue. Worth replacing anyway as the Battery is only a couple of quid.
