Dashboard Lights
200h
how do you increase the brightness of the dashboard lights on the ct
when you put your headlights on the dash lights dim but for me they are too dim
i am sure there is an easy solution
Also if you have them full on then if fitted the auto dim for night driving on the sat nav won't operate. It's in the manual around page 47 - no not a geek just coincidentally checking why mine won't auto dim last nite
thanks you are right and i'm stupid i didn't see that dial must be blocked from view by the steering wheel
the only dial i had seen is the headlight height adjuster
thanks again
