Hi guys, does anybody no the traction control system on the is250 I press the button to switch it off so that the light comes on, but after probably about 30 seconds(but haven't timed it) the light then goes out, is this correct?
The traction control cannot be turned off.
It will be deactivated temporarily by the button but will come back on again if there is no reason for it to be off, or if you drive faster than a snail.
