Diesel Injector Part No For Is220D
Akt4r
Hello All,
Having recently bought an IS220d I have been experiencing a number of
problems:
At the end of first day of owning the engine management light came on and
when I used the OBD reader it gave out a P2002 code. I found a local company
that had experience with removing IS220d DPF, blocking the 5th injector and
wiring in the emulator. I took the car to them the following day and the
removed the DPF.
After a couple of weeks of driving the car back I noticed white smoke on
cold star up which would last for approx 30-60 secs and then disappear when I
drove off. I also noticed that there was little hesitation between
1200-1500 rpm on light throttle. The engine management light then came on
again, this time error code was P0400, EGR fault. So I had the EGR
cleaned and the error code wiped. However the problem still remained.
Last Friday I took the car to a diesel specialist to have the fuel pump and
the injectors checked. They told me that injectors 3 & 4 readings
were not what they should be and they went on to remove them to carry out
further tests. The bench tests indicated that injectors 3 & 4 were
faulty.
I've since done a search on eBay and I've found the following injectors:
http://www.ebay.co.uk/itm/New-Denso-Diesel-Injector-295900-0110-Lexus-IS220-23670-26011-/281070604115?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item41711d0f53
I also found some other sellers on eBay but the injectors don't have the
tail coming off them like my current injectors do?
http://www.ebay.co.uk/itm/BRAND-NEW-DENSO-INJECTOR-23670-26060-/171317388999?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27e34fe6c7
http://www.ebay.co.uk/itm/DENSO-Diesel-Fuel-Injector-Common-Rail-Toyota-RAV-4-Avensis-Lexus-IS-/231333796563?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35dc919ad3
Does anyone know of any other places where I could purchase these injectors
at a more competitive price?
Little update. There seems to be various part no's for these diesel
injectors. However I don’t think all the part no's are compatible?
I want to try and understand if there was some kind of update whereby the Denso
injectors originally fitted when the car was manufactured were superseded later
in the production cycle of the vehicle?
My car is fitted with Part No 23670-26011
On Euro car parts website they recommend 23670-26020
http://www.eurocarparts.com/ecp/c/Lexus_IS_2.2_2006/p/car-parts/engine-parts/fuel-and-engine-management/fuel-injectors/?432820085&1&e3ef3327028340c284104148eee16928258ef17b&000993
These injectors look the same as those currently fitted on my car and have
the tail with plug connector on the end of it.
The other alternative part no that I found was 23670-26060
These injectors look different to my current injectors as they have
connector plug on top of the injector instead of the electrical tail with the
plug connector.
Now the question; As my car is fitted with 23670-26011, would it run
OK if I were to fit 2 injectors with different part no's i.e. injectors with
23670-26020?
  • 6 months later...
Hey guys im looking for 4 diesel injectectors for my Auris SR180, same engine as the is220d. part number 23670-26020 my email address is dtunha@gmail.com
plug connector.
23670-26020?
The injectors have to be coded to the car, the same injectors are used in the Avensis diesel engine, there are some 2nd hand ones on eBay.
Another option is to have yours reconditioned,there was an article in Car Mechanics the other month regarding recon units.
Where did you come from? Hey no problem Toyota and Lexus are the same family :)
Try here
