Is200 Springs And Shock Absorbers
CrocodileHunter
does anybody know the difference between the standard suspension setups?
I have a late 2001 sport model which I believe is a facelift model. I took it for an MOT and I have a leaking rear shock absorber and a snapped front coil spring so need some replacements.
most online suppliers seen to only list one type of spring for all models which cannot be correct if the sport models came with slightly lower suspension as standard? its seems the same issue with shock absorbers too. buypartsby list the parts at a good price but I just want to be sure its the right bits for my car.
I don't want to buy a pair of front springs and end up with the front of the car higher than it is now, I assume it is only the springs that were different between the sport models and se models and the shocks are the same?
does anybody know as searching the web seems to find conflicting information. Any help would be much appreciated!
thanks
