Std Radio To Factory Sat Nav In Mk2 Gs300
Morning,
Had a search and found a few double din installs but nothing that answersnmy question, which is - is it possible to take out the std radio n climate unit and swap it for the sat nav head unit?
Is the wiring loom simply plug n play with the current CD changer, except adding the loom from the sat nat disc reader.
Many thanks in advance
Sam
To be honest not sure,however if the IS 200 is anything to go by, then would probably say no,might be easier to get and install after market stereo with sat nav.I stand to be corrected though lol
+1 to that from the perspective of the is200. Someone on here tried it a while back. The picture of the cabling laid out on his drive was scary.
  • 4 weeks later...
On the You Tube I see is one guy from America is swap the old unit to sat nav unit,he have a connectors cable fit in an done!!!!
This is for Is 250
