Fuel System Issues
Cleer
Hey guys,
I just got myself a beautiful 2000 IS 200 and I am already having issues with the fuel system. When I try to turnover the car the alternator and the starter engage and work fine but no fuel goes into the engine. I pulled the lines that are connected off and there was moisture but no fuel coming out. I'm stumped as where the filter and the pump are located to see if those are the issue and if not I have no clue what to look for.
You really need to get your fuel pressure checked before going any further, the fuel pressure regulator is integrated into the fuel pump assembly, although you have fuel flow from the pump you do not know without testing if the correct pressure is being acheived.
