Maybe I'm wrong, but I think I've read about the door mirrors on an SE-L automatically turning inwards when the vehicle is locked ? Mine don't ! I usually lock by using the rubber switch on the door handle, but locking using the key fob doesn't do it either. Couldn't find any reference in the manual.
Do I have this wrong, or is there a fix ?
Many thanks.
Might be wrong but I think this feature only came in on the facelift version......09 onwards.
There is a mod kit available to add the feature. If you search thru this forum you will find it. The mod comes from a chap in Australia.
No I'm afraid your motor doesn't have the 'folding option' when you lock the doors. they only fold by pressing the button on the panel on the drivers door but, because you have this button you are able to fit the Po-40 modification which really is very easy and, is well worth doing.
