Bg244 & Ar6200
scott1977
Hi guys, just got the BG244 and AR6200.
Obviously I just chuck the BG244 into the tank before filling, but is it better on half a tank or a full tank?
What's the easiest way to use the AR6200, without having to get the calculator out each time I put fuel in?
Thanks in advance
Scott.
I used these products when I had my 220d. Found them very effective.
When my tank was nearly empty I put the whole can of BG in and then top up with 50/60 litres of fuel immediately...thereby thoroughly mixing it.
The AR ... I used to put in 5ml then 50 litres of fuel straight on top to mix again.
  • 4 weeks later...
That's right, Powerenhancer. i've just ordered some AR6400 for initial use and then I will continue with the AR6200 at every fill-up. I've done this with my 220d and my 250 and I intend to continue with the 300h
Good stuff methinks!
