Skyline Engine Conversion
Hi guys
basically i have a Lexus IS200 sport with a RB25 engine conversion iv got the Skyline engine and box running a power FC ecu full exhaust fuel pump induction kit hybrid turbo twin plate clutch alloy rad coilovers etc 330bhp
my main problem is my speedo and rev counter does not work does anyone know how to get the standard clocks working or is it not possible?
thanks Ryan
the only thing i can think of is you need to see if your power fc ecu is receiving speed and rev data if it is you can tap into the wires and wire it to the lexus speed and rev wires or you can find out where the standard sensors for the speed and revs for the rb25 was and wire them into the lexus wires that is if the sensors are still there if no then you need to get the sensors fitted.
just had a look at the lexus wiring diagram and it's a red cable that receives the speed signal so you need to connect the skyline speed sensor to a red cable on the lexus wiring.
