Please Help For The Keyfob Problem About Is200
Hi everyone, I am new for is200 and also for this forum. I have a problem with my 2000 is200.
As normal, when I push the lock button on my keyfob, the thief detection system will be actived (beep and light once);the front mirror will be closed and the door will be locked.
However, a few days ago after I wash my car, problem happen! When I push the lock button, the thief detection system can be actived and the front mirror will be closed, but the door cannot be locked!!
From now, i need to close the door by key and than active the thief detection system. Anyone have any ideas for my situration and what can I do??
Thank.
Thank.
Thank.
is it the same with your spare key ?
As Chris said, the mirrors don't close on lock as standard, so you will have an aftermarket box fitted to control this. I expect that the wiring wasn't done very well, and has been left exposed and either shorted against the metal inside the door, or get wet when you washed it and that's why your locks aren't working on remote.
Thx all your reply.
Since I can lock all the door from the centre panel(in the driver door), but I cannot lock by the remote.
Are there have 2 different mechanical system to control the locking system(remote/centre lock)? Because I want to find out is it the mechanical or the remote signal problem.
