Where Can I Get Eibach Anti Roll Bars?
RIO
Hi All,
Sorry if something has already been posted but I'm after an Eibach anti roll bar kit or something similar. Does anyone know where I can get them?
Also if anyone's used them, any feedback would be grateful,
Thanks in advance
To be honest I'm not sure you can get them new anymore, the Eibachs were branded as TTE ARB's, Someone may correct me but I believe this is the case.
It maybe worth having a chat with someone such as Fensport as they are listing the TRD anti-roll bar for the IS and are also Eibach dealers so they maybe able to help you in your quest
Thanks Janey some great info,
I phoned Fensport and they confirmed they are discontinued, they were not even sure anyone does them anymore so looks like I'll be asking someone for some second hand ones :(.
I got mine from TDI tuning. Took a few months as they were special order from Germany but worth it. If you can't find any next best are the Cusco ones which do make a difference and try some wheel spacers. Gives it more stability and fills the arches really well. Eibach 15mm at the front and 25mm at the back is perfect on Eibach springs. Good luck.
Cheers Andy,
I was hoping you might pop up as I'd seen a post before about you having them. I've already upgraded to eibach springs which are much better! I will give TDI a call and see what you can do,
Funny enough I was looking at wheel spacers as well, sounds like I am copying you!!!
How much of a differents did you notice after the new bars?
Hi Rio,
I noticed more with the roll bars than the springs, it corners flatter and gives a bit more stability on roundabouts. The spacers really make it look very different as well as improving handling with a wider track. And having them all Eibach means they will work well together. The only downside for me was that the back end still looked too high on the springs which is why I went to coil overs to get a flat stance.
Be good to hear you thoughts when you have them fitted.
Ahhh I am itching to get them now!! I'll post back with results at some point.
I know what you mean about the back end it does still look a bit raised for my liking, trouble is the car only had new shock last year. I'll try the Anti roll bars and go from there :)
Adam
Hi Andy,
Sorry out of interest how much did you pay for the roll bars?
There is loads of American sites that ship to the UK but they are listed as IS300, as far as I know the chassis are exactly the same, all that was different was the engine (3L) and some cosmetics??
Adam
