Ls400 Wheels - Help!
malcolmdc
Have found a lovely set of upgrade wheels and tyres (I think) for my LS400mk1. Original fit 15" but these are 16" with ET of 31. I believe the originals should be ET 35-40someting so does this mean a spacer of about 5 mm needed, or would they fit as is with 225/55-16 tyres, which are the right diameter to stay speedo-safe? Anybody out there know about these things?
Straight fit on a series I, no caliper clearance to worry about and wheels will easily clear suspension and arches with such a small difference in offset so no spacers needed.
PDC is obviously 114.3, are the wheels Lexus or aftermarket?
Sounds like a good buy to me, just make sure that you get the correct type of wheel nuts as aftermarket nuts are usually the tapered type while OEM Lexus use sleeved nuts.
Fitting the wrong ones may result in damage to the wheels and the risk of them coming loose.
