Is the rear jacking point on the differential ? I will.be using a floor jack. which point should I use , 1 or 2 (see picture please). Is there chance of damaging the drain plug ? Should i keep a piece of wood in between or is that not safe ? Thanks.
post-53425-0-49152700-1451685779_thumb.j
post-53425-0-65920900-1451686086_thumb.p
You can also put a jack under the diff (avoid the drain plug and don't put anything between the jack and diff) - and at the front you can use the centre of the crossmember in front of the oil pan.
That info is in the Owners Manual (P271 in my edition) and also in the workshop manual - Repair Instruction - vehicle lift and support positions
The diff casing and the fins are very strong. Position the saddle carefully and centrally, with the car on level ground and you'll be fine. The saddle should fit in that square area of fins clear of the drain plug.
