GS300 amp bypass/Aftermarket stereo
Hello all,
I had a hard time finding any solid info on an correct amp bypass lead so I thought I would share my finding. I have an GS300 from 2000 without navigation.
I bought the amp bypass from autoleads called PC2-93-4 on eBay and it states that it would be an direct fit. That was of course not the case. The connectors are the right ones and the lead is long enough to reach the speaker connectors at the amp but the pins are wrong. I looked at a schematic and with a small screwdriver it fairly easy to move the pins.
Ignition 12V+ goes in the amp bypass lead to the amp but I could not find any pin for that, however there is IGN+ available in one of the original stereo connectors located behind the stereo, I cut into that and soldered on the wire from the aftermarket ISO-connector.
Next to do is connect the sub to an amplifier in the boot.
