Is200 none starter
20vturbo
Is200 6 speed manual
Hello, I hope someone can help me with my problem.
My car starts for a second, than dies.
If I try pumping the gas it makes no difference, starts, idles for a second than dies.
I've had coil packs tested, all working.
Fuel pump doesnt prime when I turn ignition on, however I have removed the fuel pump and also tested it, and it works.
The 'security' light goes out when I Insert key into ignition.
Does anyone know what I can test next?
  • 2 months later...
Looks like someone has added something,have you tried pulling them and noticed anything not working .Have you checked the hose to the TB could be an air leak
Codes and codes again.  Get them read.  It will almost certainly point you in the right direction, otherwise it's a bit of a guessing game, with possible needless expense.
