Aftermarket front seats
andyk134
Has anyone changed their front seats to something a bit more supportive? I realise being electric and heated might be a problem (but then be honest how often do you actually use them!). if so what have you put in and how do they feel?
Thanks for your help
I'll be putting Toyota MR2 MK3 Roadster seats in my Lexus soon.
3 of the 4 bolt mounting holes already match up with the mounting points in the lexus. It's just one of the bolt hole mounts at the back needs cut off and welded back on to match the rest facing downwards. Also the cable for the seatbelt sensor light plugs in no problem :)
You can pick the seats up pretty cheap online. I'm re-using ones out of my roadster I crashed, mine are cloth but you could easily source some leather ones if that matches your interior better.
