smutts
Potential fix for is220d, white smoke, smells of diesel, poor mpg,
Ok mine was really bad , every 1000 miles, after a Battery disconnecting? I mean you couldn't see anything in the mirrors bad 😒 , nothing was being used , water, oil ect , and apart from that , it ran perfectly ... Right now though since the additive and Battery disconnecting , and a good run .... Nothing 2000 miles and counting .
Must add though even when it was really bad it passed an MOT ? No problems ...
On 2017-5-18 at 0:33 PM, rattler1968 said:
Ok mine was really bad , every 1000 miles, after a battery disconnecting? I mean you couldn't see anything in the mirrors bad 😒 , nothing was being used , water, oil ect , and apart from that , it ran perfectly ... Right now though since the additive and battery disconnecting , and a good run .... Nothing 2000 miles and counting .
Yes, the same to me -- nothing was being used and it ran perfectly except the smoke. Although I have not disconnected the Battery, there is no smoke seen from the mirrors recently, which may be due to the warm weather. If smoke appears next time, I will have a try to disconnect the batter to check this method.
That's great. I am always worried it can not pass an MOT due to the smoke. With your experience, I have confidence^-^
Hey anyone here tried the fix for the wiggling wires ? Smutts is not here anymore and its a shame because I really wanted to talk with him
My is220d is still smoking :( and 25mpg at best
My is220d is still smoking 😞 and 25mpg at best
My IS220D is still smoking as well (one puff of smoke for one second, then randomly happened again a few seconds later on the motorway).
Around 39 mpg.
Really hope someone can help.
Has any one failed an MOT with this problem? I am still disconnecting the Battery for 15 mins , it resets , and smoke free for a 1000 miles or so ? ..
I used SMUTTS solution and it worked for a while, probably because I do lots of motorway driving.
I did a Terraclean and that helped for a bit. I've started to use better fuel and that seems to help.
It recently returned (after a fill up of supermarket fuel!) and I couldn't clear the fault long enough to do a burn on the motorway. So this time I decided bite the bullet and clean out the EGR.
That was the right move. It is the EGR: chock full of carbon soot. It is easy to clean out; it took me 2 hours.
Before the clean, I had intermittent white smoke, and sporadic rattling and vibration in the engine, then LIMP mode (with "Check VSC" and warning lights displayed). After I cleaned it, the car was back up to power and... best of all... I didn't notice the engine.
I used these videos to work out how:
  • Club Hybrid Poll
  • 205 Hybrid Reliability
    1. 1. If you were to consider buying a Hybrid model over 5 years old, would you be worried about the reliability of the Hybrid system?
      • Not really as Hybrid systems are always reliable
      • Not if it had a Manufacturers Warranty on the Hybrid system
      • I would not buy a Hybrid model over 5 years old
