Noise after replacing timing and drive belts
Harrysmate
need a bit of help and advice please!
I just replaced the timing belt and all the drive belts on my is200 (never done it before), everything went okay but I now have a squeel when engine is idling. The noise seems to disappear at higher revs. Could it be the water pump which wasn't noisy before or is it possible that I have the wrong tension on the drive belt, and if so how do I check it?
Any advice would be appreciated - Thanks
alos posted this on my status - got confused!
  • 5 years later...
Hello did you found out what it was? Cause I’m experiencing the same problem on my IS200
