All done.  In the end there were 2 compressors to choose from both by Denso and I bought the wrong one, schoolboy error.  Apart from them looking very different the price is different too, £285 v £355, Mine is the expensive one! Independent garage near Ringwood did evacuation, compressor change, regas and test for £140.  All good now but I'm £1600 lighter after that and the MOT, that's nearly the value of the car!
  • 6 months later...
I'm struggling to figure out the correct compressor for my 2007 250 SE-L. Am I right in reading that the DCP51001 turned out to be wrong for a 2007?
My Part number on sticker is 6SBU16C/447260-1465. But notice the DCP51001 is a 6SEU16C. Any help appreciated finding the right part. I've got a local air con specialist who will fit if I get one and my alternative is 2nd hand which I'm a little wary of.
Eeeek my AC was causing those revs the other day.
However I had the Battery off the day before for something else and after a drive it settled so I put it down to ECU reset.
Will keep an eye on it as my car is same age as all of yours despite only doing 75k....
