Is200 towbar wiring HELP
hi just fitted a towbar to my Lexus but I'm stuck on the wiring I need to know what colour are the wires for each light on the car so I can connect to the relay cheers
This company has a list of makes and models for towbar wiring but nothing comes up when I click on the Lexus IS200, may be worth giving them a call to see if they will provide the PDF for a small charge.
http://www.rydertowing.co.uk/car-data/list-products.aspx
Either this or trace each wire for rear lights,brake lights and indicators to the bulb sockets to get the colour codes.
http://www.ebay.co.uk/itm/7-Pin-Car-Trailer-Caravan-12V-Towing-Bar-Light-Wiring-Circuit-Tester-Plug-Socket-/281975750290?hash=item41a7107e92:g:y8AAAOSwAuNW8OXu
Back at my old workplace we used to have something like this; you basically  plug in the wires from the harness and towbar wiring and then it lights up when connected correctly and operated.
There are a few guides? out there like this but no idea if it will apply for your case, I've never fitted one before :D
