IS220D Fuel pump question (non-starter)
JP_83
Hi, I have an is220D (07) non-stater at the moment, car just died less than a mile from home and wont start since.
The issue is fuel related, I have accessed the in tank fuel pump and with a test light I can confirm the fuel pump works when using the priming function with the satellite switch, with a good flow to the high pressure pump. However the in tank pump is not energized when you initially turn on the ignition or while cranking, I have checked all fuses and relays and nothing appears to be blown.
My question, is there any sensor etc. that could be faulty that would prevent the ecu from powering the pump while cranking? I have not fully checked wiring but with the priming function working I am confident it should be good.
All and any suggestions welcome at this stage.
Thanks for reading.
  • 6 years later...
