Does anyone have a problem with the Bluetooth dropping all the time? I know I should borrow someone's phone and see if it still happens but the connection can last 20 minutes, all day or not connect at all. The usual problem is that it won't connect at all. When i check the Bluetooth on the phone it says that it is connected to the car but the car says otherwise. The phone is a Nokia Lumia 735 (windows 10).
Any ideas?
My Bluetooth occasionally won't connect but a reset of the Bluetooth on my phone always sorts it out. Never experienced it dropping though. I have an Iphone 6S.
if it's saying it's connected on your phone, I'd definitely try a different phone to see if you still get the same problems as it sounds like an issue with the Bluetooth on the car to me.
Thanks Jonathan, I was beginning to think that I was going to have to reply to my own post!:laugh:
I will have to try and prise a phone off someone
