LS430 Front Wishbone - Rear Bush Carrier
c33
Hi folks, I'm just in the process of replacing the big rear bush on the front wishbones and I've noticed there is the potential for a bit of adjustment when bolting everything back up - the inner bolt hole is slotted and the outer is significantly over size. It's a very similar setup to older 3 series BMWs that have the hole in the "lollipop" bush offset on the M models to increase castor and it makes a really noticeable change in the handling when you replace the standard concentric bush on non-M cars, so I obviously want to get it right on the Lexus.
Is there a correct position to adjust the carrier to as pulling the rear of the wishbone in should theoretically change the castor angle
Regards
Iain
Sorry for the late response,
I'm not too familiar with geometry set up but I read somewhere to mark any adjustable part to ensure it goes back where it was then have an alignment check done.
The US LOC tends to have more members with lowered suspension mods, it may be worth posting on there also for more responses.
