Injectors
elvis20002
Hello lads.
I have a problem,with one of injectors on my is220d.
Is any alternative,to change injectors from AVENSIS 2.2?Because Lexus are well exspencive.Average 200 pounds per one.Set of four are 700.
Avensis injectors are around 60-80 pounds per one.
Thanks for yours advices.
If you can get the part code you can check on www.toyodiy.com to see what vehicles use the same part. I suspect they use the same injector, the engine is essentially identical - certainly the 175 bhp engine, not sure if the lower power units use different injectors.
