Help With Gs300 Headlight Washer Needed
igdirect
I need instructions on how to get at the base of the OS headlamp washer built into the bumper of my GS300 Mk1. The water supply tube has come off the washer unit and simply needs reattaching. Trouble is, it's well hidden!
So, what do I unscrew / remove / put to one side / swear at to get at the little b****r?
Any advice gratefully received!
Cheers,
Ian
you have to remove most of the o/s wing liner and engine undercover to gain access to the pipes. its not to difficult to do but the clips can break easily on older models.
