Hi all. Came out this evening to find a pool of ps fluid in the drive. The hose from the reservoir to the pump on my MK4 has split. Can a replacement be found or will any correct sized rubber hose work ok. If so what sized hose do I need?
I've bodger it with masses of gaffer tape for now.
Many thanks in advance. Matt 😁👍
Contact the guys at the Power Steering Store - www.powersteeringstore.co.uk - who should be able to help you. They supplied me with some hose to connect to the long U shaped power steering pipe that runs in front of the radiator. Look in the Contact Us section at the bottom of the page on the home page of their website.
