Water Pump failing - advice needed
Noticed a bit of a rattle a couple of days ago. Popped the bonnet today and it seems the water pump is on its way out. It’s my only car and I use it to commute to work, round trip 20 miles per day. I’m planning to take it to my local mechanic on Friday morning, should I be concerned about driving it for the next four days? Also, any idea of cost? Europarts has a pump for £130 so maybe a couple of hours labour, £250 ish? Thanks in advance!
Water pumps seem to be cheaper here
https://www.autodoc.co.uk/car-parts/oem/1610039436
(I've not used them, simply a google search on the part number 16100-39436)
Also, don't be afraid to ring a Lexus dealer and ask for prices, europarts are not always cheaper than Lexus.
If it's not leaking, or you're not seeing high temps, then you should be fine. Mine is a little noisy but has been for about 3 years!
I’ve not noticed high temps but I’ve not really been on a run since I noticed the noise. I’ll check again tomorrow for any sign of leaks but I didn’t notice any when I checked Early. Thanks for the help
If you feel confident enough would you do it yourself?
I definitely would after seeing this great 'How To ' video and it does not require any special tools or intrusion into any other specialist systems ie A/C. Have watched the vid a couple of times looking for any 'troublesome' sections and it looks a pretty straightforward operation if you take your time and double check as you go.
if the new pump casing has a ground down area then it is almost certainly an Oem pump with the logo removed! And make sure it comes with a new metal/rubber gasket, some don't. Eurocarparts Don't mention the seal/gasket so don't bank on getting one included but this genuine one does, and Could be got for a bit less than the listed price I reckon!
http://www.ebay.co.uk/itm/NEW-GENUINE-LEXUS-IS-IS220-IS250-GS-GS300-GS350-GS450H-WATER-PUMP-16100-39436/222433417809?epid=650154012&hash=item33ca109a51:g:YIEAAOSwCU1YwBqH
( please note I am Not and do not Know the seller!)
cheers Paul m.
Independent. Part was £90 plus vat, billed three hours labour. I’d love to have a go myself but it’s my only car so it needed to be done for Monday.
Edit - yes, coolant changed and was itemised on invoice
Good result there then! £227 all in, but me being me would still be getting up close and personal and doing it myself, admittedly got a second car so no pressure on having to getting it done in a certain time frame. But once again glad you're all sorted ( for another 90k anyway!!!)
cheers paul m.
