Joern
Tuning experience
Is there anyone here who has remapped or chipped the IS 220D for over a year and would like to share their experience?
Considering getting a remap to 215hk including EGR delete. How is this engine going to handle it for longer periods of time?
Quite standard reply form me... If the search function would work I would be able to copy paste it here.
The problem with original IS220d was that it kept blowing gaskets and was generally unreliable... what Lexus did to solve this?! They reduced the power (from 177hp) in face-lift model and called it 200d  (150hp) event thought it is basically the same 2.231L engine (called 2AD-FTV instead of 2AD-FHV)
What that suggests? If you do anything to improve this engine you need to "de-tune" it.
Several members here have had their is220d remapped and reported good power gains and less turbo lag.
However it is a fragile and unreliable engine and Lexus detuned it to 150bhp for good reason.
Adding more power to this engine is asking for trouble.
I guess it would be wise to start stocking up few extra head gaskets if you plan for 215hp... you know just in case :whistling:
Head gaskets blowing up seems like an overheating issue?
Is this going to be a problem in colder climates like norway?
That's not the only reason head gaskets fail.
It is more like ... overheating is the "symptom" and there are several underlying "causes"... mostly around engine design, as well under-rated head gasket. Lexus latter fitted "upgraded" gaskets to cars which have been repaired under warranty. One way or another IS220d is not great base for tuning project, it can be tuned as any trubo diesel, but it is inherently unreliable and flawed engine - not what you want if you have plants to increase power. I could make it run more economical, smoother and with less smoke however - no problem with that.
Mine was remapped and everything is ok. Oil change max on 10 000 km. Cooling turbo, drive normally when engine is cold. This engines doesn't have 177/400. Medium result is about 160/370. Weakest which i saw was 120/315 no dtc error , live data seems to be ok, will be replaced scv valve and it could be little more. I decied to buy my lex cuz it have new engine from lexus dealer. Before lex i had e46 coupe R6 2,5 , great car but exploitation was very expensive.
Referring to the remap in this case it should be different approach, lex its not like bmw's diesel where from 3.0d m57n you can make great results 400/788 , here you need to FIX what the factory broke  or not know how to do. Serial engine program i think was made by a asian kid, enormous turbo lag , fuel consumption 12+ l/100km, egr and dpf problems. They also can't make diagnosis and you need to diag your car mostly from live data. Here you have 0-1 system - sensor not work/sensor work. When for example SCV not working 100% ok, car can drive, but you lose power - obd code readers will not tell anything. I made remap not for performance, but for pleasure with driving. Numbers are not important on dyno, important is how car drive after mods.
Look at dyno and you will see factory soft and fixed soft
PERFORMANCE - NO
PLEASURE WITH DRIVING - YES
177/400 is at the engine, you comparing it with results at the wheels.
Yes, but too big differences in my opinion. My ex bmw had factory 170/245 when was on dyno (and measured 30 degree of C ) result was 166/240. In lower temperatures i think result will be better.
As long as "at the engine" it is 177/400... it is correct. How much energy is wasted in the drive train will vary greatly from car to car.
  • Similar Content
    • By holiday
      Hi
      I had just purchased a Ct200H from Nottingham and noticed while driving that the windscreen is slightly chipped as per the photos can this be repaired or does it need a replacement.
      My dad is worried about getting it replaced as it will damage the car and the trims. Please advise, we had had opted for the replacement and the glass will be a branded Lexus glass but my father is worried as it will damage the car.
      I appreciate your guidance.
    • By joelfigueira
      Hi all,
      can an anyone recommend a good replacement gear knob for is220d. Got quoted from Lexus £150 quid for a new one. Just wanting to know if anyone has replace there’s and if so what with.
      ta
      Joel
    • By Ian J. Parsley
      I'm not keen on car reviews really but Carwow's do have an interesting aspect of "five likes and dislikes", which are often fun and quirky.
      If we maybe limit it to three for each model, what are ours?
      For my recently handed over 3rd generation IS, I would say...
      Dislikes
      The boot lid is just awful; a big thing you have to slam down, often with a double dose of elbow on the way. Not premium!
      There are too many similar buttons in the centre, so you really have to look (for example to check you're clearing the windscreen rather than turning on the rear demister).
      The parking sensor on notification on the dash appears on the main display but to one side, leaving it asymmetrical and torturing anyone with even a hint of OCD...
      Likes
      The turning circle is outstanding; this is a shorter car than most of its rivals and when it comes to U-turns, well, these are U-turns rather than three-point turns...
      One of the USB ports works as an ideal key holder - stick a USB stick on your house keys (and your car key in your pocket), leave them here, and you'll never lose them (and you can play music or transfer routes to your nav while you're at it).
      The change in dials in sports mode is just cool!
      Over to other owners...
    • By Ian J. Parsley
      My household is theoretically the owner of three current Lexus models until the end of the month (see signature). I thought I'd do a brief review of each on the relevant thread, essentially aimed at helping people considering.
      Model
      This was a MY14 IS300h Lux, registered July 2013. It was in fact the first 3rd gen IS in Northern Ireland.
      Lux trim added leather and auto sound control ("fake gears") with paddles; and this one had Premium Nav (including remote journey planner, DVD player and reverse camera with full guidelines). It lacked extras such as HUD, electric/memory seats and lane guidance.
      Interior
      Initially I really liked the interior and the materials oozed quality and stood the test of time. The seats are extraordinarily comfortable and the analogue clock adds a touch of call. The touch sensors for the climate control were good and utile.
      The dash display is fine; nothing to write home about but a few nice touches like the change to regular layout in sport mode.
      I must say, over time I came to find the central section a little bland, almost like something straight out of a Casio wris****ch.
      Storage is ok; there is a large centre console (for the rear-wheel drive) with plenty of space. One problem is the cup holders are single size and too far back. Boot space is fine too, but the boot lid just lacked quality and really just had to be slammed down. Storage is somewhat limited in the back, however; this is compensated for by a nice arm rest.
      Exterior
      This is subjective of course, but I think the IS is a superb-looking car, particularly but not only from the front.
      Infotainment
      This is not a Lexus strong point; the nav map looks a bit old and some of the options take so,e working out - it took me weeks to work out how to turn the voice off but leave turn-by-turn instructions on the dash on.
      A major and frustrating omission is volume control. I had this on a 1998 Volvo! I know the IS is quiet, but I still found myself shuffling the volume on my music regularly at higher speed to counter the slight road noise.
      For all that, it does basically work, the DAB worked fine for the most part, and the DVD screen quality was outstanding. Also, I did like the split screens on the nav.
      Driving
      Without reservation, I found this a superb car to drive, contrary to many of the UK reviews. The turning circle was staggeringly good; steering was direct; yet the ride was generally comfortable. With the modes and the paddles I found I could drive the same route two very different ways. 223bhp also moves you away swiftly when you want to - but it is all so pleasant because it is so gloriously quiet (with even wind deflectors contributing to the silence) you often don't. Really terrific, for me.
      The engine is terrific too, and the "growl" referred to in reviews is simply non-existent. But turn the ASD off; it's a gimmick!
      Reliability
      Not a single problem beyond the odd infotainment hitch. Tyres are repaired for free too. The car also remained in good nick inside and out - the next owner will scarcely believe it has 40k miles on it.
      Out of interest, I tended to average around 48mpg in the summer and 45mpg in the winter (see other reviews on other threads for comparison).
      Summary
      For anyone in the market for a mid-range premium family saloon, I recommend a test drive unreservedly.
      Infotainment lets the car down a little; others are now moving well ahead. Also, the hybrid isn't quite the obvious economical option it was four years ago with plenty of outright electric now on the market.
      However, for comfort and quality (and in my view looks), I don't think the IS can be beaten. It remains a great financial proposition particularly as a business car, and for reliability and customer service it is a clear class leader.
    • By olliesgrandad
      Well at last the V5c arrived today for my new toy and I wasted no time in going online and allocating my private plate to my GS300h. A quick phone call and I was at Lexus Cheltenham where they swiftly made up and fitted a new set of plates gratis together with supplying a free touch up paint set. I have now been able to register the car on the  online portal and see the full history stored. When I have a bit of time I will go through it.
