Rear or front engine
I've just moved to an NX after 3 years with an IS. Aside from the obvious differences I keep finding odds and ends that are different for no good reason.
Case in point the two attached pictures from the display.  On the IS version the engine is on the left on the NX it's on the right, and it's a different engine graphic.
it's been a boring day......
Makes sense - in the NX its transversely mounted, hence the position of the engine.
The IS has a longitudinal mounted engine.
Not really sure why they are swapped around though
I just checked mine. The engine is definitely in the same place on my NX as it was on my IS albeit turned through 90 degrees as mentioned above. How can we trust everything we read on the internet if the graphics in our cars are also wrong?
