Wiper heater not working
Guest bigbullhead
Guest bigbullhead
 Wanted to defrost the wipers this morning but they did not come on nor the light that illuminates could it be a fuse??
Edited by bigbullhead
Guest bigbullhead
Checked the fuses that was ok then I removed the switch to check if the wire was loose and found no wires connected now I am sure I used it in feb as it was new to me ( I also had it in the old one that worked. I did have a alpine exit-dab radio fitted in that area so was thinking the wire might have been pull somewhere I can’t see it
  • 4 weeks later...
Guest bigbullhead
That is correct I have had the covers off under steering wheel and can’t find a connector to put on the switch I was thinking it was pulled out during fitting of DAB maybe when pulling  a wire through etc
Gotta be there somewhere and when manufactures make car wiring looms they do not normally leave 'ends' unnecessarily any longer than absolutely required so it shouldn't be far away!
paul m.
