Lower ball joint advice
iffy
My front lower ball joint is very worn. Can users please share their experience in changing this part out? Also what brand should I look to replace with? And where should I buy from. Thanks
I had someone who knew what they were doing change them for me. I watched the whole duration, it's a case of having the correct tools, and remembering where everything goes etc.
I would use Toyota ball joints from the dealer, or Moog if you can find them. Other than that I wouldn't bother as the cheap ones wont last too long at all based on many iS200's i've seen with a wheel through the wing because of them.
True. OK then lexus it is. Hopefully Barry gadgy will give me a 10 percent discount. But I like dojng my own work and will buy any tool required, in that case is it advisable to do it or not?
