Hi all,
Performed a search cant find this issue on the site....
The car flashes the indicators once/twice when I lock/unlock from the fob = normal.
Recently, when I place my hand into the door handle to trigger keyless entry, it flashes 6 times and the locks trigger around the car. This happens even if I have already unlocked the car on the fob.
Does anyone know why this might be? Perhaps its a warning for something or a symptom of another fault?
Indicators working perfectly for use when driving.
Bill
Edited by Billnick
Symptoms updated/clarified
Dunno' if this is any help?
Hmmmm unfortunately not. I am getting the 5 flashes but when I press the unlock button once.
I have always deadlocked my car (2 button clicks) but it has not ever caused the additional flashes.
Maybe I will get the manual out, see if there are any clues in there.
Have you tried a 're-set', battery dis-connect for a few minutes, note you will have to re-learn each window ( and sunroof?) and may lose trip figures and radio pre-sets.
paul m.
On other cars I've owned, multiple flashes on unlocking meant the alarm had gone off (and had reset) at some point during the locked period.
If everything is working as it should then yes I agree it is 'trying to tell you something'
but it is a shame that it is very difficult to find out What!!!
paul m.
I am going to dive into the manual tonight or at the weekend.
If I get no answers, I'll reset via the Battery.
Great thanks for doing that (I am at work right now)
My brother borrowed my car whilst I was away, I will ask him if anything unusual happened, otherwise disconnect the Battery.
If someone other than you Has used it then it might be because multiple button presses of the key fob may have changed some of the entry system settings.
paul m.
Not too sure on that to be honest, having fitted a new Battery to my 250 recently nothing has changed with the entry system but then again I not sure if 'everything' might have been in the default setting anyway.
I haven't read all this but post #9 mentions 6 flashes.
https://www.boards.ie/b/thread/2056319050
paul m.
Hmmm that thread sounds more like it.
I confirmed the symptoms last night:
Lock and unlock on the key fob works as normal with 1 and 2 flashes.
It is when I put my hand into the drivers door handle to trigger the key less entry, it flashes 6 times and sounds like the other doors open and lock etc.
Sadly, I did not try those doors to see if they were unlocked.
I will do some proper investigation in the morning tomorrow and then disconnect the Battery.
Ok. I disconnected the Battery yesterday whilst i replaced my headlight bulbs.
Upon re connection the symptoms of the multiple flashing seemed to have been cured.
That was until later that evening after another journey when it did the same again.....hand in the door handle and 5/6 flashes.
I fitted a mirror auto closure box back in 2015. I am worried that one of my solders might have come loose and is shorting out. I have contacted Michael who supplied the box to see if he is aware of or seen the 5/6 flashes before.....
Hope it isn't a deeper electrical issue.
Found this vid from link on CL
Owner in this thread had a result from dealer with just a loose connection in door, ( shown on invoice attached in post #27)
https://www.clublexus.com/forums/is-3rd-gen-2014-present/749540-multiple-beeps-when-unlocking-door-handle-is350f-2.html
I know it is Gen 3 but I would not expect locking system to be million miles different, and you have a PO-40 fitted so door wiring has in fact been disturbed!
paul m.
