13 hours ago, OldTrout said:
Phil,
The various posts refer to the GS450h dampers not GS300. These are much cheaper.
John
Ah, I see. Thanks for that info, you just learn so much from the LOC!
I'm presuming you would get some warning message on the dash if these were fitted? Knowing our luck that could mean a MOT fail :(
Really wish stuff like this and TPMS could be coded out...
As long as the actuator motor is still in place on top of the shock strut no warnings will be given..
John
