RX450H Luxury 2016 KPH Speedo Reading
I’m taking my latest generation RX450h to France for the summer. Unlike the F Sport I don’t have the option for a digital KPH readout on the speedo and the KPH markings on the Speedo are so feint that I can’t read them clearly, particularly when the sunlight catches them through the panoramic roof. Just wondering if anyone has found a solution for this- it seems amazing on a £50K+ car that you can’t change the Speedo from mph to kph easily (it is after all still a “digital” display as a rev counter appears when I select “sport” mode. Am I missing something obvious. Thanks in advance
Easiest way to is to go through the multi-information display settings in the instrument cluster itself.
Should be under settings>units
I think the above method is for the navigation.
4 hours ago, Felltiger said:
Thanks Rayaans- same result through the cluster I’m afraid- just changes consumption data. “Should’ve bought an F-Sport” to mimic a well known advert 😉
Perhaps turning the brightness up of the instrument cluster will help so you can read the smaller KM/H readings
