Lexus CT200Advance Satnav problem
Keith Harrisson
According to the Nav handbook,
Press the “MENU” button on the Remote Touch, then select “Setup”.
2 Select “General” on the “Setup” screen.
3 Select “Delete personal data”
4 Select “Delete”
5 Select “Yes”
The following personal data can be deleted or returned to their default settings: • Maintenance conditions • Maintenance information off setting • Memory point • Password settings for backing up and copying memory points • Areas to avoid • Previous points • Route guidance • Route trace • Phonebook data • Call history data • Speed dial data • Bluetooth® phone data • Phone sound settings • Phone display settings • Message settings • Audio setting • Bluetooth® audio setting • Search engine settings • Opening image data • Screen off image data
